Build to Order Spec - X-Plane 11
28 Sep 2021
Leeds
Hi Everyone,
New to the forums and looking at a gaming PC for X-Plane 11, though aside from being aware of the minimum and recommended specifications, struggling to figure out the right PC and configuration.
Would appreciate people thoughts on this build https://www.overclockers.co.uk/ocuk...3600-powered-by-asus-gaming-pc-fs-1dl-og.html with 32GB Vulcan Z T-Force.
I see in the configurator I have the option of GeForce RTX 3060 Dual OC V2 12GB GDDR6 LHR Graphics Card or RTX 3060Ti Dual Mini V2 LHR 8GB GDDR6 PCI-Express Graphics Card. Aside from the former being 12GB and the later being 8GB, does one being a Ti make a difference?
Thanks in advance for the help!
the ti is a step up from the 3060 in terms of performance about 25 to 30% better fps...worth the £20
3060ti
Cuda Cores 4864
Tensor Cores 152
RT Cores 38
3060
Cuda Cores 3584
Tensor Cores 101
RT Cores 25
3060ti
Cuda Cores 4864
Tensor Cores 152
RT Cores 38
3060
Cuda Cores 3584
Tensor Cores 101
RT Cores 25
Thanks for the input - would you say the step up to Ti in terms of cores outweighs the extra 4GB on the 3060?
