Hi all.
I installed a new mobile and cpu. B550 tomahawk and 5800x.
Coming from a crosshair vi and a 1700.
Rest of the system
760seasonic psu
Corsair 3000mhz ddr4 16gb
1tb wd m.2
250gb samsung ssd
2tb seagate hdd
3080fe
Ae5 sound card
Instal went well windows recognised and I reactivated against new hardware.
But then I started getting Blue screen crashes
Multiple different reason
Fltmgr.sys
System service exception
NTFS
All seem to have the stop code as page fault in none pages area.
I've tried a reinstall of windows, including wiping all data. Tried with only 1 ram stick. Removed all drives bar os.
Sfc scannow will run and highlight no problems but then not long after I get a crash and sfc tells me I have corrupt files it's unable to fix. Now each time I run sfc scan now I get a ceash part way through with the fltmgr error?
I've spent 2 days on this now is it likely I have a faulty CPU or Mobo? I haven't yet moved back to my 1700 and x370 but that will be my next step
Rest of the system
760seasonic psu
1tb wd m.2
250gb samsung ssd
2tb seagate hdd
3080fe
Ae5 sound card
Fltmgr.sys
NTFS
