Build won't power on -thoughts?
18 Mar 2011
Hey guys, I did a build for someone a few months back. Everything was fine for a while and then the system became unstable and started to BSOD a lot. I checked the system, and the RAM had failed. The supplier (not OcUK) exchanged the RAM for me today. I've come back to the build, put the new RAM in and turned it on and...nothing. No fans spin up, nothing.
The build was absolutely fine a week ago (other than the faulty RAM) and I haven't turned it on since. I've check the power cable and it's fine, tried in a different socket and checked the ATX and CPU power cable connections as well as the power switch jumper. So, any ideas?
