Im dont have any projects to work on at the moment and im on a bit of a tight budget for the next month so i have been thinking about building a custom PC case from scratch.
Over the next few months im planning on puting phase cooling in for my CPU and watercooling for the graphics cards. This will not fit in my current case and rather then spending £100 on a good case i would prefer to spend £50 and build something myself
Im thinking of going for a desktop/shuttle/cube style of case in layers so i could have the WC pump and res in the bottom with the phase cooler, Motherboard in the middle section and drives at the top with the WC Rad (though im still thinking of building a rad that will go outside my house
If anyone has any links to any similar projects i wouldnt mind some links
Found a few via google but the more the better.
The only thing im not 100% sure on is what material to make it out of. Aluminum/steel would be the best bet but is likely to be more expensive and harder for me to work with.
I would like it to be all acrilic but im worried about the fact that the case wont be grounded and that acrilic builds up a static charge pretty quickly. Anyone know a way to work around this?
).If anyone has any links to any similar projects i wouldnt mind some links
Found a few via google but the more the better.The only thing im not 100% sure on is what material to make it out of. Aluminum/steel would be the best bet but is likely to be more expensive and harder for me to work with.
