BUILDING A CSS LAN SERVER
20 Mar 2005
I'd like to put together a Dedicated server for the LAN events I run a 16 player server from a laptop @66 tick (1.5ghz AMD) at the moment, which seems to work. Soon im doing a 20 player LAN and I would like to have more than one CSS server running.
So could I have help with the following.
Would the spec below be able to run 2x 10 player CSS servers and 1x 20 player CSS server at the same time.
3800 X2
1GB Ram
80Gb Sata 2 Hdd
128mb ATI 9250SE
400w psu
if not, can you recommend a spec that can.
Many thanks - Friction
i run 5 cs servers online from a p4 3.2 with a gb of ram and its perfect. so that spec is perfect for more than 1 server!
