- 25 Aug 2010
Hi,
I'm planning to buy a laptop for my dad.
Now, I would want to build some kind of desktop box which will contain the following:
- 1 HDD for extra storage of data that won't fit on the laptop's SSD
- 1 HDD to backup the laptop's SSD
- 1 HDD to backup the aforementionned storage HDD
- Possibly a CD/DVD burner in case the laptop I choose doesn't have one
- Extra USB ports
I would like to have all of this in one small box. Is this possible to build/buy?
The idea is that when at home, he can just connect the laptop to the "docking" box (I'm guessing through a USB cable), and have instant access to all the hard drives, DVD drive and the extra USB ports. I'd want it to be simple.
I guess I'd need a power supply and fans to go with the case. Is this workable? I DON'T want to be building a full computer.
Also, I'm aware that having the storage HDD and its backup HDD in the same box is not ideal, because if there is a power **** up then I'll loose both. Is there a way round this - e.g. have the storage HDD powered off a separate power supply, or even the laptop's power from the powered USB cable?
Sorry if this sounds stoopid - I'm new at all this. I'm not planning to build this minute, but I would like to know if this setup is possible. Thoughts or advice appreciated.
- Extra USB ports
