Hi guys,
I'm looking to build a gaming rig (heavy duty). I looked at the PC configurator section and built the perfect PC for about £1300. However, I can only stretch as far as £1000. Would building it from scratch make it less pricey?
My main issue, is that I'm a noob and don't know whether components will work together or not.
The rig:
- It doesn't need a display as I'll be using my iMac (late 2009) as the display. therefore the GPU must have a Display Port.
- I was thinking of using a Nvidia GTX 580 but perhaps 2x Nvidia GTX 570s (Which one will be better?)
- I'd like either an Intel i3 (or is it i2?) or an i5 CPU.
- 12GB - 16GB RAM (therefore a 64bit OS is required.)
- As for the mother board and power supply etc. etc. I couldn't tell my left from my right. Could you advise me on this?
- I would love to be able to buy parts and replace them in the future, is there anything I need to do to make sure it's upgradable in the future?
My main aim is to play games like Battlefield 3 as close to max as is humanly affordable.
So what do you think of the setup? Yay or Nay?
Kind regards,
Mike
P.S. go easily on the terminology. Thanks.
The rig:
Kind regards,
Mike
