- 25 Nov 2009
I currently have 2 single garages next that I want to flatten, lay a new concrete base and build 1 single garage. Under permitted development.
My understanding is that it needs to be under 2.5m tall and no bigger than 30m2 which leaves be with a 5m x 6m space and a flat roof. Now I'm no builder but fairly handy with general house renovation type stuff and I'm sure I can turn my hand to a bit of brickwork...
What would be the best construction method bearing in mind I want as much as possible to be DIY and kinda looking to keep costs down.
Plan loosely but up for debate is to lay a slab and sit 2 courses of engineering bricks down at the base... then essentially build a 4x2 timber stud structure clad with OSB both internally and externally, clad externally. Sectional single garage door on the front and a UPVC door on the rear for access from the garden.
Thanks for your help guys
