- 9 May 2009
Hi, nice to meet you all
I hope you can help me as i am going to build 2 pcs one for my normal home use and the other for a media centre, I have bought windows 7 Pro for my home pc and windows 7 hime for my media centre.
Now the thing is i dont know where to start on i have looked around and thought these would be a good start.
Antec Fusion Remote HTPC Case
Intel Pentium Dual-Core E5300 "LGA775 Core 2" 2.60GHz (800FSB)
Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive
the things i dont know is what
PSU
Graphics card
Sound card if i need one ?
Harddrive
to use as i am after a system that will play everything even high quality 1080p MKV files that are the most power hungry videos to play.
the hard drive i was thinking of getting
Western Digital Scorpio Blue 500GB 5400RPM SATA-II 8MB Cache
as these drives are very low in noise levels but i dont know how good they will be for booting up windows 7 and transfering to the drive using the network.
the other thing is graphics cards what do i need to play the most demanding movies types as i am not interested in games at all and want the most silent gfx card you can get but at teh same time handle windiows 7 and playing the most demanding mkv files or higher.
do gfx cards output all audio formats using the hdmi port of the gfx card or do i need to buy a sound card as well as i have a pioneer 5090 tv i want to get the best into this tv.
does the case above come with a remote also ? and can i use any type of meida centre program on the pc.
its all doing my head in abit and was hoping you can give me some help on this subject as my xbox xbmc is just to old and slow now for hd.
i hope you can help and give me some advice on the subject
thanks again
PSU
Graphics card
Harddrive
thanks again
