Hi,
I posted a thread the other day about building a small file server. I think I've decided to go for a mini-itx based system for the low power consumption and noise.
Firstly, I've been looking at a Mini ITX retailer and I'm considering the following boards:
Jetway J7F2 1.5GHz C7D Mini-ITX Motherboard (about 80 plus VAT)
EPIA CN 13000G C7 Mini-ITX Board (about 100 plus VAT)
The Jetway seem to be cheaper than the VIA ones, are they as good/reliable?
Also, I'd want to get a bigger case that the Mini ITX ones. I'm planning on having a CDrom, a IDE hard drive (which I have spare) for the OS and a SATA drive as the main data store.
If I pick up any micro ATX case will it take the mini ITX board, or is this something I need to check carefully about?
Lastly, power supplies. I'd be driving a CDrom and two hard drives, so the 50W external power supplies won't be enough. I guess I'm after a low power, and preferably silent, internal PSU (assuming I can get a micro ATX case) - any suggestions?
Thanks for your help,
Jon
Jon
