building a new rig, need some advice :)
11 Jan 2008
hey, this is what i've come up with:
Case: Lian Li B25B or Antec P182
Mobo: Asus P5E3 Premium (Intel X48)
CPU: Q6600 G0 stepping (with the Noctua NH-U12P CPU Cooler)
GPU: Asus 9800 GX2
RAM: OCZ 4GB DDR3 1333MHz ReaperX
HDD: Western Digital Raptor 150GB
OS: Windows Home Basic Vista 64Bit
I have no idea which PSU to get, opinions would be nice
I'm also worried that I might have physical compatibility issues with the RAM as the Heatsink awkward and large......
as already said, go for home premium.
for the psu. I'm sure a corsair 620W would be powerful enough, and these are very highly recommended by many people.
With your HDD, raptors are very expensive for the performance and storage they offer for the price. If I were you I'd look into having a RAID0 array instead, as that would offer superior performance due to the higher bandwidth of such a setup.
I would definitely recommend the Corsair HX620W. I have the 520W version and can't fault it.
I also agree with Ben W. You would be better getting 2 different hard drives and running them in RAID0. The Raptors are also very noisy!
cheers guyys,
i thought the raptors were pretty good, 10,000rpm and 4.6 sec seek time
im not sure what raid 0, bandwidth means but i'll go on the harddrive section of the forum and try educate myself :(
what Harddrive would you recommend? i thought what most people done was get 2 HDD's... 1 fast one like the raptor ( is it really that noisy?) for programs
and 1 slower higher capacity one for storage...
ok this is the updated list
Case: Lian Li PC-P60B or Antec P182
GPU: Asus 9800 GX2
RAM: OCZ 4GB DDR3 1333MHz ReaperX (2x2GB)
HDD: Western Digital Raptor 150GB (x2 in RAID 0)
OS: Windows Vista home premium 64Bit
PSU: Corsair 750W TX
not sure about the optical drive?? need some opinions, i know HD is no more. Should i just get a Plexter dual layer DVDRW or go all out and get the LG Blu-Ray Rewriter & HD-DVD. Would i ever use the blue-ray? lol
i guess i dont need a floppy drive? or do i? if you guys think i do then i guess i could get the floppy/card reader combo, or just get the AKASA AllInOne RED USB2 5¼" 21 Multifunction Panel with Card Reader....
anything else i have left out or consider getting? this'll be my first build :s
http://www.overclockers.co.uk/showproduct.php?prodid=CD-077-LO&groupid=701&catid=10&subcat=951
I have two of these drives and I can't fault them, fast writing speed and compatible with a number of different formats.
I have a floppy disk drive although I don't use it very often. I imagine it would prove useful if you needed to update your BIOS or create a boot disc for Windows. If you opted to get a floppy disc drive I would definately consider getting it in the form of a card reader drive as you mention (minimises the need for USB cables for digital camera and nice features like an extra USB port etc).
As for Blu-ray drives, unless you're going to hook your PC up to an HD TV or have a good quality high definition monitor, I wouldn't bother. I have been considering getting one myself, but I don't have either of those things and therefore I won't reap the benefits of a blu-ray drive.
