Building a new rig, spec inside with some questions
12 Nov 2006
South shields
hey all. ive not been in the loop as far as pc hardware goes for around 1 year or so
Now im looking at upgrading my old a64 rig, im replacing everything even down the the mouse lol. my budget is £2000 and this is what i have came up with. i just need to know im not going to run into any compatability problems, or anything that may effect the new rig in some way.
here is the spec which im looking at
Corsair 4GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x2GB) Supplied with Airflow Fan (TWIN2X4096-8500C5DF)
Creative Sound Blaster X-Fi Xtreme Gamer Fatal1ty Professional Series 7.1 Sound Card - Retail
Razer Diamondback 3G Frost Blue 1800dpi Gaming Mouse - Retail
Asus P5Q Deluxe Intel P45 (Socket 775) PCI-Express DDR2 Motherboard
Microsoft Windows Vista Ultimate SP1 - Retail (66R-02266)
Intel Core 2 Quad Q9450 LGA775 'Yorkfield' 2.66GHz 12MB-cache (1333FSB) Processor - Retail
LiteON DH-16D2S-02C 16x Serial ATA DVD-ROM (Black) - OEM
BFG GeForce GTX 280 OC 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Antec Twelve Hundred Ultimate Gaming Case
Samsung SM-2232BW Pebble 22" Widescreen LCD Monitor - Glossy Black
Akasa Rounded Floppy Cable (0.45m) - Black
Logitech G11 Gaming Keyboard (967929-0120)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Arctic Silver Thermal Epoxy (7g)
Akasa SATA-2 45cm Silver Data Cable
Corsair HX 1000W ATX2.2 Modular SLI Compliant PSU (CMPSU-1000HXUK)
Pioneer DVR-215DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Sony Floppy Drive - Black
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) x2
this is whats it's costing Total : £1,928.40
now the questions i have
whats this business about sound acceleration under vista.. will the sound card i picked be ok, i just read that vista does not use direct sound.. or something along them lines.
also is the psu enough.. regarding the rails, i read it's best to have more amps on thr 12v rail, as you can see im not so clued up where this is concerned so thats why im asking.
Now my main concern is the motherboard.. i have no idea on the different chipsets intel have on offer, as you can see i will be using a nvidia card and i have no plans for sli. i just want a good quality board thats going to be stable. and is the memory good enough for the motherboard.
I will be gaming on the rig mostly so it needs to be stable.
thank for for your help, as soon as i get enough input i will be ordering this today or tomorrow.
again many thanks.
ok a 2k budget :)
here we go:
It is all compatible although the soundcard is probably not going to work well if at all, I'd suggest the Asus Xonar DX2 if gaming is the aim instead as it has no such driver problems.
The PSU is massive overkill, something like the HX 620w by the same manufacturer will be more than sufficient for almost anything you could add to that PC and it will save money as well.
The P45 is supposed to be a good chipset, quite close to the X series in performance and overclocking ability. It doesn't matter that you are using a Nvidia card with it.
//edit or take the basics of shaffaaf27s specification and tweak it slightly as if you aren't overclocking then PC8500 isn't strictly necessary. :)
People may disagree, but i would personally get the Asus Maximus II Formula and 1 X 4870. You can Xfire as needed at a later date. Also, swap the 24inch monitor for the OCUK value 24 and the 9450 for a Q6600 and last but not least, get the TRU 120 instead of the TT.
thanks for a replies people. i did change a few things around and ive now placed the order to be delivered this saturday :D
Akasa Rounded Floppy Cable (0.45m) - Blue 1 £1.99
Sony Floppy Drive - Black 1 £4.99
Xbox 360 Wireless Networking Adapter 1 £44.99
Microsoft Windows Vista Ultimate SP1 - Retail (66R-02266) 1 £162.99
Intel Core 2 Quad Q9450 LGA775 'Yorkfield' 2.66GHz 12MB-cache (1333FSB) Processor - Retail 1 £177.99
Asus Rampage Formula Intel X48 (Socket 775) PCI-Express DDR2 Motherboard 1 £159.99
Corsair 4GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x2GB) Supplied with Airflow Fan (TWIN2X4096-8500C5DF) 1 £79.99
BFG GeForce GTX 280 OC 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail 1 £299.99
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) 2 £163.98
LiteON DH-16D2S-02C 16x Serial ATA DVD-ROM (Black) - OEM 1 £9.99
Pioneer DVR-215DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM 1 £14.99
Arctic Silver 5 Thermal Compound (3.5g) 2 £7.98
Akasa SATA-2 60cm Silver Data Cable 3 £14.97
Asus Xonar D2X 7.1 PCI-Express Sound Card - Retail 1 £94.99
Antec Twelve Hundred Ultimate Gaming Case 1 £91.99
Logitech G11 Gaming Keyboard (967929-0120) 1 £32.99
Corsair HX 1000W ATX2.2 Modular SLI Compliant PSU (CMPSU-1000HXUK) 1 £139.99
LG L227WT 22" Widescreen LCD Monitor - Black 1 £189.99
Razer Diamondback 3G Frost Blue 1800dpi Gaming Mouse - Retail 1 £22.99
Belkin F1DG102WUK Switch2 Wireless USB KVM Switch 1 £30.99
Zalman CNPS9500A-LED CPU Cooler (Socket 478/754/939/940/LGA775)
the only issue i have it fitting the cpu heat sink ive never fitted a back plate to the motherboard or whatever you do. but apart from that im happy and im looking forward to playing games again on the pc :)
again thanks for the input
