- 12 Jan 2006
Hi Folks
I am currently putting together a E6600, Nforce 680i and 8800GTS spec for my new build which I will start in the next few weeks.
I already know the components I want to build the system but I cannot make up my mind as to the case.
I have looked at both the Antec P180 and 900 Gaming Case and although each have their merits they also have failing that make me think twice.
My needs are as follows:
1. A case big enough for a G80 based system
2. A removable Motherboard tray (my Coolermaster Pretorian had one and they are a blessing)
3. Dust Filters on the intakes (my house gets quite dusty and I don't want to suffocate my system)
4. Less then 100 pounds (excluding VAT)
5. Relatively silent running (no 80mm Case fans, my old case had them and they are too loud for me)
6. See through side panel (not a requirement as such, just a wish)
If you are able to help I will be very grateful. If you have a particluar case yourself that may fit my needs or has a similar system inside please can you tell me how it was to set up/noise etc.
Thanks for your help
