as the title says looking to build a great performing gaming pc,ive picked these components out.
REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
CP-142-AM AMD Opteron UP 146 San Diego 2.0GHz 1MB Cache 939
£129.95 £129.95
CA-000-TG Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU
£54.95 £54.95
MB-018-DF DFI LanParty NF4 SLI-DR EXPERT (Socket 939) PCI-Express Motherboard
£124.95 £124.95
GX-027-GW Gainward BLISS GeForce 6800 GS "Goes Like Hell" 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-027-GW)
£149.95 £149.95
CA-054-CM CoolerMaster Stacker STC-T01 - Silver Trim (No PSU)
£89.50 £89.50
MY-002-MK Mushkin 2GB DDR XP4000 Redline Extreme Performance Dual Channel Kit (2x1GB)
£199.95 £199.95
FG-000-AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR)
£15.95 £15.95
HD-046-WD Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD)
£55.50 £55.50
FG-024-AK Akasa AK-183-L2B Ultra Quiet 120mm Fan - 3 pin (FG-024-AK)
£8.95 £26.85
CD-027-NE NEC ND4551 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Beige) - OEM (CD-027-NE)
£23.95 £23.95
OS-001-MS Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01528) (OS-001-MS)
£51.95 £51.95
Subtotal £923.45
VAT £161.61
Total £1,085.06
looking to overclock this lot to get the best out of it,its possible to overclock the chip to fx-57 speeds,and the rest is all good for overclocking.
what do you guys think? anything good or bad?
will it run well?
£129.95 £129.95
£54.95 £54.95
£124.95 £124.95
£149.95 £149.95
£89.50 £89.50
£199.95 £199.95
£15.95 £15.95
£55.50 £55.50
£8.95 £26.85
£23.95 £23.95
£51.95 £51.95
Subtotal £923.45
VAT £161.61
Total £1,085.06
will it run well?
