Hey, So I'm building a my 2nd ever pc and I'm running into issues I didn't have during the first. I suspect its due to me using budget components this time.
My first question is. My case and fans all have 3 pin rgb connectors however my Asus mobo has a 4 pin header for rgb. I just can't figure out how to piece it all together am I missing an adaptor of some sort or am I just being silly?
My second question is. My mobo Asus Prime H610M-E D4 only has two case fan headers so I've bought a splitter allowing me to plug 3 fans into 1 header but I cant find the amp limit for each header on my mobo so I'm unsure if I can use all three fans on that one header. Does anyone know or knows a way I can find out this information please?
Thanks in advance for your help!
Stephen.
Edit: I used two fan splitters and put 0.70 amp into the one nearest to CPU fan and 0.30 in a different one and they both seem to be running fine touch wood.
Stephen.
