- 11 Mar 2023
- Bristol
Hi there.
I am building a PC. I was going to go for a 1Kw PSU as the PSU was on sale for the same price as a 850W (and i thought it gives me a bit of headroom) However, that PSU is now out of stock for that price. SO, i headed to a PSU calculator and it says the 850W would be more than enough for my needs... How accurate are they?
Here is my setup:
I don't currently have a 4080 (I have a 2070) but i plan to upgrade next year/to a 5080.
[td]
CPU
AMD Ryzen 7 7800X3D
Motherboard:
Asrock X670E Pro RS
RAM
CORSAIR VENGEANCE RGB 32GB DDR5 6000Mhz RAM
SSD
2
HHD x4
GPU Currently have a 2070 but plan on upgrading to a 4080/5070 next year.
Standalone Soundcard
According to the PSU calculator 620W is fine so a 850W is perfect.. Is this correct?
I don't really plan on overclocking the GPU but may try and push a bit more out the CPU for ***** and giggles but its not a deal breaker
Ill have about 5-6 fans and a All in one rad cooler for the CPU.
how accurate are these calculators? Ive seen some say they;re okay if you allow a bit of headroom while others say they're utterly useless.
Here is my setup:
[td]
CPU
AMD Ryzen 7 7800X3D
Motherboard:
Asrock X670E Pro RS
RAM
SSD
2
HHD x4
