Building a Pc with a VERY old case
Caporegime
8 Sep 2005
Norrbotten, Sweden.
Im moved back to Sweden and im trying to put my ASUS P67 and bits into a very old case ( AMD seprom used to live in it )that ive scrounged.
It has raised bumps where the brass stand-offs can go effectively replacing their need I haven't seen or built a PC using this kind of case for nearly 10+ years and im a bit panicked.
I am right thinking its 100% safe to just mount the P67 PRO onto these directly?
They are the exact same height as a brass stand-off and only when on these will the IO shield and back bits line up correctly.
I dont have any ceramic washers so ill be improvising with cut up plastic bottles if i need anything... (kaboom)
Fast answers please cos i want to get this sucker safe in the case before bed time.
Thanks !
