Building a SATA NAS pc - freenas - some questions!
12 Feb 2004
Manchester
hi guys
i have an old p4 hp desktop pc that i want to use as a file server/nas on my home network
ive heard about freenas and i want to give it a go
thing is i have a 500gb sata drve that i want to use and the pc hasn't got sata ports
if i was to get a sata pci card, would this setup work?
when booting up freenas would i have to specify sata drivers for freenas to see the sata hard drive?
thanks!
if the NAS box says it takes sata drives, you dont need anythign extra.
I have a dlink NAS just plugged in the hard drive and off it went.
nice and neat to have a NAS box instead of a whole pc sitting there as a server, imo..
aye. i would love a ll in one unit, but i have this pc doing nothing, so might aswell make use for it
i will be using freenas.org, which is FreeBSD based OS for NAS
il have a look on the their website to see if can find any info
thanks
sorry i misunderstood.
start again.
if you want to run your NAS software on your old pc then yes you can get a sata controller card to add your sata drive.
It depends on a number of factors.
Easy way.. just get an IDE - SATA converter for a few £
The throughput of ATA 133 MB/sec far exceeds the 30MB/sec typical of gigabit and 8MB/Sec typical of 100Mbps Lan
You can use an SATA card, drivers shouldn't be required provided the card is supported by freeBSD but I have't yet found a list so I just used and adaptor.
The best freenas installs are via a USB key of the motherboard supports USB booting. This gives most options with the drive if you want to raid it later.
AD
