I'm using 2 470s so the fans like to rev up to 95% ish.
Using the akasa eclipse 62 case and using too many HDDs to remove the cage, is there anyway of setting up a water loop with just the graphics cards? If so, any chance you would spec it for me on OCUK so if it looks achievable by my noob self I can just order it without worry of wrong size fittings?
The option for adding the CPU to the loop would be good too
I have 2 spare 5.25" bays for res & pump, or pump could sit on the base?
