- 22 Feb 2014
I am building my own woodworking bench out of 4x2 and 3x2 timber supplied by local building supplier.
As with all timber you have to deal with twist and bends etc.
the bench will be 2100mm long when finished.
I am making it with 8 legs in total, I am up to the stage where I have the top frame built and attached to the 4 corner legs.
All the legs were cut at the same time so that I could get them all to the same length, and if I offer one of the middle legs up to the legs that are on the bench now they are the same height, however when i put the middle leg in its actual position it sits proud of the top of the bench by about a 1mm
I have put a long spirit level on to check and it looks straight (no visible light coming through under the level) but I am able to press down slightly on the middle of the sprit level.
which I can only assume means the length of timber running down the side of my bench has a very slight bow in it, both sides are the same.
I can obviously shave the leg down by 1mm to get the top level but not sure if this is deemed acceptable, what else can I do though as no timber that is bought is perfect I checked every piece of timber I had delivered and selected what I saw by eye as the 2 straightest pieces for the longest part of the bench
