Hi all,
Bit of an odd one that I know little about..
Basically, I will be distributing materials on a USB stick and wish to have a splash page for for the contents of the stick so that users can easily load the files without looking at the file structure/explorer.
I am wondering what the options are for this? Do the CD autorun options apply to USB?
The issue I am struggling with is that the stick contents will change and I cant manage updating the menu for each one. The menu has to be dynamic and pull the filenames from the stick and put them in the menu. Unfortunately I don't have any application programming knowledge, which I assume is what I need.
Anyone have any advice? Tips? Links to what I might need?
