Building First Budget Gaming Rig.
1 Aug 2011
Bristol.
Hello,
I'm looking to build my first budget gaming rig for about 800£.
The cost has to include the OS, Mouse&Keyboard.
I would like the parts to be from overclockers.co.uk,
I have already come up with a build but i dont know if its any good or the components are compatible with eachother.
If i can get any better parts for the same price tell me, I would like to know if it can run most games on high-max graphics.
P.S I also want an Intel build.
So heres my rig -
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card £179.99
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
Asus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard £129.98
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-00599) £79.99
Corsair Builder Series CX 600W V2 '80 Plus' Certified Power Supply (CMPSU-600CXV2) £59.99
Cooler Master CM-690 II Lite Dominator Case - Black £59.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £44.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) x2 £52.78
Samsung SH-S222AB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Blaze K3285 Multimedia Slim USB Keyboard - Black £7.99
Logitech S96 PS/2 Optical Wheel Mouse Black - OEM (953688-1600) £5.99
Total - £825.17 with Next day delivery.
Thanks Guys.
Think I will sub my GPU and PSU for the ones you guys said, is there anything else I can change to make this a decent gaming rig.
P.S. do you think this could play Battlefield: Bad Company 2&3 maxed out?
Thanks.
Get a good keyboard and mouse, a Logitech MX518 and microsoft sidewinder X4.
You want peripherals that respond to your input in the heat of battle.
Thanks.
not maxed out but high settings, yes
Ok so i guess ill just have to stick with some cheap keyboard and mouse then, but ill probably try and save up for a razer mouse and keyboard.
