final build i think what do you think
cpu - amd 8320
gpu - powercolor radeon 7870 2gb
mobo- gigabyte 990 fx ud3
cooler - cm hyper 412s
ram- corsair 2*4 gb vengence
psu- corsair 600w 80+ bronze
case - got one but have to double check
Is anything wrong with this as without the case comes to about £570 and is it compatible thanks
Also, the 8320 is not the best chip, the 8350 is better value for money. You would be crazy to not go Intel. They are quicker, more efficient, run cooler and overclock better than any AMD chip. You'd be wasting your money!!
It`s his money, let him waste it. All but one member has advised him to go Intel and he still insists on AMD. Some people, just have to learn the hard way and at some expense.![]()
Oh, thanks that sounds good. What case should i get then?
You'll want to read up a bit more before you start this build
Cases take different sized motherboards, ATX, Micro ATX and Mini ITX. ATX boards are the biggest.
And there was me thinking the CEB motherboards were the biggest....
