Hey guys im building a pc as follows:
i5-3570k
Gigabyte z77 GA-Z77X-UD3H-WB Motherboard
Asus GTX670 Direct CU II TOP version
Corsair CMZ8GX3M2A1600C9B 8GB 1600Mhz memory
WD Caviar Black 2TB WD2002FAEX HDD
Samsung 830 series 128GB SSD
Fractal Design Define R3 USB 3.0 Version
and importantly,
Corsair GS700 700W PSU
I have a few questions if anybody has some spare time helping me with:
1. I am building this computer myself for the first time. I understand a lot about computers but I am no expert. Do i literally piece them together using antistatic wrist band and mat? Is there any configuring in the bios or firmware updates i need to do or anything else?
2. Is that 700W PSU big enough for the system requirements?
3. Do you reckon I would need to buy a sound card? I have bought some Corsair sp2500 speakers and listen to music all day. I would like good quality audio and dont mind buying a 40 pounds sound card, but only if the sound will be a lot better?
4. I am going to be overclocking my CPU for the first time. Which cpu cooler would you recommend for under 30 pounds? I've seen good reviews for the Xigmatek Gaia SD1283, ZALMAN CNPS 10X Performa and Zaward Vapor 120. Which one is best, and are there any better for the price?
Many thanks for anyone who helps!!
i5-3570k
and importantly,
everything just fits really. Generally the bioses of today are a lot more understandable, (the Gigabyte one is definitely). You'll need to download drivers and install your operating system, but it's really straightforward, often just a case of going to the manufacturer's website
