Hey everyone. As in the title, I'm building my first PC and I would really appreciate some advice on component selection from anyone willing to give some. Hopefully the following info can give you a good idea for what will suit me!
What will I use it for?
I will be using it as a home PC, for mainly casual stuff (browsing), but it is also not strange for me to dabble in other things once in a while, such as playing a game, editing a video, and a great deal of other stuff. I would prefer to have a bigger capacity than I need on average. I do play a bit of Minecraft occasionally and would like to be able to run that with various mods, shaders etc.
I know that it is generally accepted that you can't future proof computers, but having said that, I have had my current computer (i3, 4gb RAM) for around 5 years, and in all honesty I could probably use it for another 5 years if I wanted to. I want to build something that is a considerable upgrade and would suit me for another 5+ years, which isn't out of the question with my computer needs.
What is my budget?
I don't really have a strict budget. From all the test builds I've put together, it seems to add up to about £1400ish. Assume that there is no budget, but if the price of a component is way higher than the other high end options, you can probably count that out.
I have a real lack of expertise regarding some of the components, with such a vast array of options to choose from, and also considering compatibility, I need some help.
I'll give a brief summary on each component with what I think I'll want roughly to hopefully assist anyone willing to share advice:
CPU
I currently have an Intel i3-2100 @ 3.10 GHZ and would definitely like to upgrade this. It seems the natural progressions would be an i5 or i7. I'd be leaning towards the i7 unless convinced otherwise - I don't know much about this at all.
CPU Heatsink
No idea. Something quiet and reliable I guess.
RAM
I currently have 4GB, I wanted to bump it up to 32GB, but then convinced myself that having no real troubles currently with 4GB, I think 16GB would be a nice enough boost.
Graphics Card
I don't have a clue. So many many options. I'd like a good one, say in the top 15%, something that wont struggle at all (I don't play extremely high spec PC games).
Case
I guess this one might be a more personal choice, but I'd like something preferably as small as possible without losing practicality and something that looks modest (no windows, bright colours or Transformer lookalikes).
Power Supply
Something that works!
Motherboard
No clue again.
Storage
I feel like I'm pretty set on a 2TB Western Digital HDD, and a secondary 250GB Samsung SSD. Can be convinced to change.
Optical Drive
Not needed.
OS
Would like to stay with Windows 7 Home Premium, could be convinced to change but most likely not.
Thanks for sticking with me! I welcome all questions and suggestions.
What is my budget?
CPU
CPU Heatsink
RAM
Graphics Card
Case
Power Supply
Motherboard
No clue again.
Storage
Optical Drive
Not needed.
OS
