So, for the longest time I've wanted to watercool my PC but never had the balls to just get stuck in and do it. The blocks that i have always liked went cheap and now i feel like i should commit to the cause!
Water Blocks: https://www.overclockers.co.uk/showproduct.php?prodid=WC-165-AQ&groupid=962&catid=1520&subcat=2767 (Acrylic Version)
This is where i get stuck as i know literally nothing about watercooling except i can make it pretty and blue with the right liquid and coolant
Can people just drop some ideas on comparable hardware to go with the blocks along with the pros and con's, that would be amazing. Whilst i want the good cooling benefits im mostly after the ascetics, if i can get both, even better.
Spec;
Case: In Win GRone E-ATX Full Tower
Power Supply: NZXT Hale Power 90+ 1000W
Motherboard: Gigabyte 990FXA-UD5 AMD 990FX
CPU: AMD FX8350 Black Edition
Memory: Avexir Blue Series 8GB DDR3 2666
Hard Drive: Samsung 250GB SSD 840 EVO
Video Card: Gainward GeForce GTX 770 Phantom x 2
Thanks in advanced for the info!
.Can people just drop some ideas on comparable hardware to go with the blocks along with the pros and con's, that would be amazing. Whilst i want the good cooling benefits im mostly after the ascetics, if i can get both, even better.
Spec;
Not seen them browsing through, would 1 pack and 2 extras be enough? 4 on the GFX / 2 on CPU / 2 into RAD / would i not need a couple more for the res ?
