Recently I have decided on the decision of buying a new pc but felt i should build one as it would be fun and yeh who cares.
I have come up with components for my new pc that total up to around 1000£
Really I would want to come up with a build with a less total amount but if you feel i need to maybye increase this amount then please tell me so. I may have even left out a crucial piece, like i said im new ive only watched a few videos on yt about pc building and learnt a few basics.
Here is what i came up with:
GPU: MSI GeForce GTX 1060 6gb
CPU: I5 8600K 3.6Ghz
RAM: 16gb HyperX (Kinda too expensive)
PSU: Formula 650W (most likely needs a change)
HDD: 1TB WD
Mother Board: MSI Z370 Intel
Case: NZXT Midi tower (idk the difference or if i would need to get a full size case.)
I assume there are other accessories ill need such as some thermal paste (if someone could also link some good thermal paste and how much id need of it that'd be lovely)
Maybe there are some wires too but I've not seen much of needed accessories apart from a cooler which brings me to my next question
With this rig will I need a buyable cooler and not be able to use the stock cooler that comes with the cpu?
So if there are alternatives to my parts that are either:
Cheaper and bareley effect the pc and keep it at a good level because maybye a different part of my computer build needs to be better for that one to work as well as it can.
More expensive but increase the rigs potential tremendously and something i might aswell save a bit more for.
Every comment/suggestion is much appreciated and remember im not an expert in this field but know what i would like to say are all the basics <3
HDD: 1TB WD
