I'm planning to build a new PC in the next few months but keep some parts from my old PC. I've built PCs before including my old one but not for several years so I'm a bit behind on some of the newer developments.
My current/old PC spec:
Corsair CX750M PSU
Asus P8Z77-V mobo
4x4GB Kingston HyperX DDR3 2400Mhz (11-13-14-32) 1.65v
Intel i7 3770K OCed to 4.4Ghz on stock voltages
Corsair H80i(v1) AIO cooler
WD 500GB SATA SSD
2x Nvidia EVGA GTX 980Ti
I'm aiming for 1920x1080 at smooth/consistent 60fps on high/ultra settings in most games for the next 2-3 years if possible. Currently I can usually maintain 60fps at med/high settings in most games but even on low settings there are occasional stutters in certain games and they always seem to happen at exactly the worst possible moment in online games, like when another player appears in front of me Tarkov or something. CPU and GPU and RAM usage are rarely above 75% (in Tarkov) so it must be either old and slow DDR3 ram or slow (compared to modern M2 drives) SATA SSD. (Yes I've spent time researching the best settings for these games). I'm hoping a mobo/cpu/ram/ssd upgrade will sort me out and also give me faster loading times too.
Planned new PC purchases:
Intel H570 chipset mobo, not sure which one (£100-150ish)
Intel i5 11600K (£230ish)
4x8GB 3200Mhz/3600Mhz Corsair Vengeance or Kingston HyperX (£200-300)
1TB NVMe PCIe4 M2 SSD (£175ish)
CPU AIO cooler (£100ish)
Total budget around £800-900
I don't care for any of this RGB lighting nonsense that is fashionable now, anything that has it must be able to turn the lighting off completely in settings.
Questions:
1. I'm assuming I can use my old PSU with the new mobo? ATX mobos still use the big 24+4 pin connectors like they have for years right? In terms of power draw the new hardware should consume similar wattage to the old so the PSU should cope fine.
2. The i5 11600k seems like a sweet spot for gaming right now and a few years down the line if I need more CPU power I can buy a used 11900K, sound about right?
3. What's the difference between the 11600, 11600K and 11600KF? I remember several years ago the 'K' meant it had an unlocked multiplier.
4. Given the difficulty of buying powerful GPUs at the moment I plan to stick with the ones I have and buy either a 3080 or 3090 on the used market in a year or two when nvidia release the 4xxx series and people are selling their 3xxx cards, assuming supply/demand of GPUs settles down by then. Sound sensible?
5. I'm seeing some of the NVMe PCIe4.0 M2 drives claim 7000MB/s read speeds. Is that actually realistically achievable? What do I need to do to make sure I can utilise all that tasty speed?
6. I'm quite confused by the huge selection of RAM, I never did quite get my head around the timings and stuff, just know that lower timing numbers are better. I'd like to use either Corsair Vengeance or Kingston HyperX again as I've never had problems with those types in the past. 32GB should be enough for gaming for a few years right? Am I going to notice the benefit of 3600Mhz (or faster) ram or should I stick to 3200Mhz and save some money? I do play one game in particular (factorio) that can be bottle-necked by ram bandwidth/speed unlike most games.
7. What's a good value AIO CPU cooler that is quiet but powerful enough to handle some mild overclocking? I'm assuming my current one pre-dates the intel 1200 socket and so will not be compatible?
8. I'm pretty sure I want the intel H570 chipset but no idea which specific mobo is the best value, any suggestions? I don't care about Ethernet speed or onboard audio/video. Solid build quality and good gaming performance is all I'm after.
Thanks.
Corsair CX750M PSU
Asus P8Z77-V mobo
WD 500GB SATA SSD
Questions:
Thanks.
