The entry-level model of the X-Fi series, the Sound Blaster X-Fi Xtreme Audio, does not actually have the EMU20K1 chip but is a re-branded Audigy SE, using the same family of chips (CA0106-WBTLF), and even the same drivers.[12] Thus, not only is all of the X-Fi–related processing performed in software, but it also lacks basic hardware acceleration just like the SB Live! 24-bit, the Audigy SE and other budget Soundblaster models. The X-Fi Xtreme Audio does not use the same drivers as the rest of the X-Fi family, some games do not recognize it as being "X-Fi capable hardware", and the device's hardware profile resembles that of older Live! and Audigy cards.
Furthermore, users have reported that it slows down some applications and games, and that rear sound in games (all) is muffled and of profoundly low quality.[13][14][15] Thus, even if the card is marketed as part of the X-Fi line, it does not belong to it technically, just like the Audigy SE doesn't technically belong to the Sound Blaster Audigy series. The card is not marketed as supporting the "X-Fi Gaming Mode" (but is still marketed as "X-Fi"), and there are no official implicit or explicit statements regarding its having hardware acceleration or not.
Lamboman's posted a good spec, but I'd switch the Antec 900 back to the P182 or the Lian Li PC-A17, as even with dust filters, the 900 will smother your nice shiny new components in the filth.
If you're going for a Soundcard, the only option for £50 is the Asus Xonar DX.
But, if you are lazy, definitely go with the other two.Thanks for advice guys. Below is what i've swaped in from the previous screenie.
Change log:
GeIL 4GB (2x2GB) PC2-6400C5 800MHz Black Dragon DDR2 Dual Channel Kit (GB24GB6400C5DC)
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail
Arctic Cooling MX-2 Thermal Compound
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
Antec Nine Hundred Ultimate Gaming Case
/Change log
Is the case a good choice - i read that dust could be a problem? and How much better(in temp) is the Turniq cooler compared to putting a freezer pro.
- Will it fit in?
Thanks again guys/gals you've been really helpful.
Crucial ballistix is the best ram 48 hour scotland rma turnaround if it ever goes wrong the rest you have o send off to tawain and places like that.
It's a shame they don't do 2gb sticks here, 2gb is fine never understood all the get 4 gb stuff when how many games actually use 2gigs of ram let alone over 2 gigs I guess if vista runs better thats the only reason to get over 2 gigs.
Had my ballistix for a year no problems at all with no cooling on them just because a few people over volt or push theirs too far doesn't mean it's dodgy ram.
