- 6 Apr 2009
- Exeter, Uk
Hiya,
Its my first post, but know a bit about PCs, and am looking at building my first PC - a tower ATX. I have budgeted about £1k! But if I can make a top quality one for less would be good! And I'm looking to get it up and running fairly quickly as my old one has blown up.
After a quick read up and look about (2 days), a pretty good combo seems to be a GA-EX58-UD5 "Gigabyte S1366 Intel X58 DDR3 ATX Audio 2GbE Lan 3 Channel" motherboard with an "Intel Nehalem i7 920 S1366 2.66GHz", although this is getting on the pricey side, and I haven't checked all specification compatibilities yet (other than socket), so thought I'd post this to try and get some feedback asap...
Does anyone know if these are a good match, and bus speeds match up etc?
Is it a good idea to go for a 1366 socket?
Is 3 channel RAM worth it (over dual-channel)?
Is DDR3 worth it? Does it have the same latency issues as early DDR2s?
Currently have PNY NVidia 7600 GS graphics card would this be up to the new system, or would I have to upgrade?
Can anyone recommend some good RAM to go with it (~4GB, DDR3 - is unbuffered Non-ECC the way to go?).
The PC will hopefully be for all sorts of applications: high end gaming, fast compilation, video editing etc...
On an aside, are wide screen/two monitor setups worth it? How many apps take advantage of it?
Many thanks..
(p.s. Already have 200GB IDE HDD, PNY NVidia 7600 GS, and good monitor if need to save cash).
Many thanks..
