Building PC
16 Nov 2012
Hey guys was wondering if this build i plan on buying all the parts are compatible and stuff.
Would the case be big enough for everything and does the cpu have a stock heatsink im lost with all this lol :P
Yes the case will be big enoug hand the CPU does have a stock heatsink. What is your budget? I'd suggest asking some of us here to do a spec for you as already I can see what can be made better.
Yep you cant post links to other competitors.
Also, for £600 I wouldn't go for a 7950 graphics card, but a 7850 instead. Then an i5 3570k instead of the one you picked, and a Z77 chipset motherboard, preferably a Z77-D3H
