Can you come to a compromise with building regs in the sense of them using their discretion or coming to an agreement if suitable action has been taken? It's a private company, not council.
Builder normally handles all this but his is away for Easter so just trying brainstorm while he is away.
I have a situation as follows:
Regs stipulate that doors opening onto the landing there is a 400mm space requirement - the door swing can't enter this area to protect people coming up the stairs and also those leaving from falling down stairs.
Example image, not mine, just example. I can draw mine if my text is confusing
I have two doors. One goes into my flat, the other goes into the attic - both doors on the same landing. The attic door swings out and does cross this 400mm line. Not massively but a bit.
I was wondering if a compromise could be made in the form of using a door with a glass window. This allows people to see out and also in to avoid collision.
.......or are building regs to the letter of the law.
