I'm about to build a new file/client server PC, with an end capacity of 10 BIG sata2 drives. prob seagates or samsung spinpoints. They're going in a CM201, as i dont want to get rid of that fantastic case, but have no other use for it at the moment. Plus it fits in the area i've earmarked for my server, and it looks good. got a 120mm fan for the rear outlet. Got all the specs sorted out really, either going to use my old XP-Mobile 45w chip on a DFI infinity, or get a new, fairly low end core2duo setup in there, with any ole nondemanding graphics, and a dvd burner
Not sure what PSU i'll need though. The main part of the PC won't need anything special, but i'm wary of running so many drives on one PSU - all mine are high end but fairly old, so i'm going to need a new one
I need a psu with BEEFY Sata power rails. i'd like one with a 120mm fan. those super big enermax psu's prob wouldn't fit in the 201. I also dont want to spend too much... would prob justify £80, as the rest of the rig, even using old mobo/gfx/ram/cpu/case is going to be around £1000.
any ideas anyone?
any ideas anyone?
