Building right now, question!
26 Dec 2003
Hiya,
So all my parts arrived, thanks Overclockers :)
Just putting everything together, taking my time. Just one question so far, but might have more...
The Enthoo Pro comes with a PWM Hub built in. One of the cables coming off it, goes to the CPU fan header. I'm wondering, which of the free Fan headers on the PWM Hub I should attach the CPU fan too?
Thanks!
Good news, not sure the cable would reach to the bottom one!
Also, am I correct in assuming, that I connect it to Sata power if its plugged into the CPU fan header?
Thanks for the quick answer
You use a Molex to connect to it, this is were the manual is little vague, some header could handle the power of several fans. I used mine connected to a Molex and so far all looks ok.
:D
I haven't done this for about 4 years! But I did manage to remember that. Helps I've booked a day off work and am taking my sweat time about it to think everything through!
