Building small, quiet pc?
11 Jan 2011
Hi, im going to be building a computer for web browsing and using microsoft office.
i will not be playing games on this computer and if i do it will only be football manager type games.
i have a budget of £600 for everything including keyboard, mouse, screen and operating system. i allready have some speakers.
what would you recommend for my budget, i want it as small and as quiet as possible.
Small as in M-atx or small as in M-itx? I have put together a build in the Bitfenix Prodigy case with three fans, totally silent. Most of the rest of the components I had spare just needed a mobo and a small SSD.
But for £600 I have n doubt the folks here will spec you a fine rig.
It does depend on how small, if it's just for word processing etc a Sandy i3 will probably do you fine... I'll have a go at speccing something up. You probably don't need a gpu either tbh.
You can go Mini ITX , prodigy build on that if you want.
Would get a much better PSU as well, one that is modular like the Coolmeraster Silent Pro.
Good motherboard though.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-073-BX
Prodigy case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-167-CM&groupid=701&catid=123&subcat=1103
CM Silent Pro PSU
Could also get a cheaper monitor if you wanted:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-060-BQ&groupid=17&catid=949&subcat=
For your uses it will be a fine CPU. As long as you don't do a lot of gaming it should last 5 years of office work at a guess.
Idleman really not meaning to be rude but.
Tiny case + non modular PSU = disaster.
Only thing I can say beats my spec (again dont take offense) is the addition of a SSD.
Tiny case + non modular PSU = disaster.Absolute nonsense.
Only thing I can say beats my spec (again dont take offense) is the addition of a SSD.The G850 is good enough for his needs.
Not meaning to be rude.:D
I agree the G850 is good enough, but the i3 will prolly last maybe a year longer? Depending what office programs can use HT.
And the PSU bit isnt nonsense :p
Where we he have room for all the cables
And say he wants a GPU a year down the line...
Revised spec, thanks on the motherboard btw ;)
YOUR BASKET
1 x Samsung S24B300HL 23.6" Widescreen LED Monitor - Black **BTS £20 CASHBACK** £119.99
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x Asus P8H77-I Intel H77 (Socket 1155) DDR3 MiniITX Motherboard £83.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x BitFenix Prodigy Mini-ITX Cube Case - Midnight Black £64.99
1 x Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £54.98
1 x Toshiba (7K1000.D) 500GB SATA 6GB/s 32MB Cache - OEM (DT01ACA050) £49.99
1 x OcUK Value 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £26.99
1 x OcUK Compact Wireless Desktop Set (6309ARF) £19.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £627.89 (includes shipping : £12.50).
Hi, would it be worth getting a ivy bridge over sandy bridge?
i have come up with this, even though i havent inclded a keyboard, mouse or screen what do you think?
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £184.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ / ST1000005) £67.99
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38G2133HC11DC01) £35.99
Pioneer 24x Internal DVR-S19LBK DVD Rewriter including Labelflash - Retail £20.99
Sub Total :
£498.26
