I have the gigabyte ga-z77n-wifi motherboard and im assembling my pc in the bitfenix prodigy case.
For cooling i have 2x120mm fans 1x200mm fan and a antec h2o 620 liquid cooling system.
There only seems to be 2 ports to plug fans into the motherboard (cpu_fan and sys_fan) and i have 4x plugs to plug in and also the pump has another plug that I can't identify what it is. (The 2x 120mm fans are push/pulling through the radiator)
Unless i haven't found all the sockets im guessing i need to plug some of the fans direct into the psu? If so which ones should i plug into which and which cables do i need to use?
Thanks sorry if some parts don't make sence, im typing this on my phone.
