Getting this one in before the slew of Carbide 540 builds, wanted to ask a question or two of this awesomely knowledgeable community as well
Build is a re-build of my current bodge-box using an el-cheapo case from a competitor. I say bodge-box because it didn't quite go according to plan...
Build will be:
- Corsair Carbide 540r (From OCUK next week)
- Gigabyte 990FX-UD3
- AMD FX 8350
- Corsair H100 (From the reconditioned batch coming in to Overclockers next week)
- 2 x MSI R7850s in Crossfire
- 16 GB Corsair Vengeance (4x4) 1600mhz
- Samsung 840 Evo 500gb
- XFX Pro 850W Black Edition
- Mechanical storage is supplied by my HTPC over the network.
- Will be using the 2 supplied fans with the H100 along with 2 x 120 Corsair SP120s in push-pull.
Not the most cutting edge of boxes I know, but Intel v AMD arguments aside it's plenty fast for what I want/need.
Now for the question... I also have in hand 3 x Akasa Vegas White LEDs strips and a Bitfenix Hydra Pro. Hydra will be managing the 3 internal Corsair 140AFs which come with the case, along with the 4 fans on the H100.
The Bitfenix Hydra has 5x 2-pin cables connected to the LED on/off switch, and the Akasa Vegas strips use what looks like some sort of proprietary 4 pin connector to daisy chain off each other, with one end going into a piggy-back standard 4 pin molex (using 2 pins).
What I want to know is, without a significant investment in electrical equipment and minimal knowledge, will there be any way to get the Vegas strips to run off the Hydra's LED controller? The Vegas strips are 12v but I have no idea what voltage the Hydra provides to the LED cable outs.
Edit: Problem (most likely) solved - picked up a molex power switch from ebay
Build will be:
- AMD FX 8350
