Built and ready to be OC'ed
3 Dec 2012
body-manc, brain-space
Thought I would just share a pic of my build, time to read up on the overclocking stuff.
FX8120 | Asus Sabertooth 990FX | Antec Kúhler H2O 920 | 8GB Vengeance RAM rated (not using) @ 2133Mhz (hmmm think i got the wrong one) | PSU crossair HX850 gold edition | MSI 7970 Lightening edition
http://sphotos-a.ak.fbcdn.net/hphotos-ak-snc7/412653_10151219126902772_1073897923_o.jpg
Image too large
slate me or congratz me, I am happy with it anyway for now, Ivy bridge on save up (may just wait for next gen tho).
damn didn't see size restrictions only kbs >20 oh well will make a new one soon :D
I suggest you read the FAQ.
Your signature is dimensionally oversized:
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
Also:
You may post images providing they are hosted by a well known image hosting website, such as imageshack, photobucket etc.. Directly linking to images on other sites that are not expressly for that purpose (known as Hotlinking) is not permitted. Hotlinked images will be removed with an infraction notice issued. Repeat offenders will be suspended. The sharing of images from your own personal web-space is acceptable providing you are the owner and give permission to do so. However, the OCUK moderation team reserve the right to replace or remove any image that is suspicious of being hotlinked or unknowingly hosted by a members personal web-space, as it is not possible to identify those where permission has been granted or otherwise. Such decisions will not be overturned. To avoid complication, we strongly advise that all images are hosted by a image host as mentioned above, which can be easily identified as so. Images containing nudity, adult or offensive material, including swearing is prohibited. Please check your images before posting. No watermarks or URLs for sites containing content that wouldn't normally be allowed such as competitors, adult sites etc. Any images of such nature will be removed and your account immediately suspended or banned. Unless otherwise agreed by the moderation team, images must be no wider than 1280 pixels wide. The only exception to this are images posted in
tags.
Also:
read the 1st as soon as he said to big, I consider my wrists slapped, changed for now, will add another soon.
thanks
Edit : just read the 2nd quote, I used a FB pic an copied its URL, take it that is a no no, or am i just thick
Tidy up the cables!
Anyway nice build, good luck with overclocking remember about voltage limits ;)
Wherever you choose to host your images you need to upload them at an acceptable size, use a host that allows image resizing or put the images in spoiler tags if they're too big.
Well tbh I had big pic, resized in paint many times as tried few times, spammed everyones news feed on FB, with 5 diff versions of that pic, untill it appeared to fit in the "guessed" allowed space (it showed it all so thought was legal, now understand, and that pic would look poo any smaller imo, so will make one within the rules)
as say, my bad, no harm, no foul
Tidy up the cables!
Remember!! I don't know them yet lol. From what have read, but not in more than one place yet (like to double, double check info on things am not sure, will make a post confirming my understanding in the OC thread, once alittle more clued up, before i make any changes, made noob mistake once, by letting AMD overdrive damage my giga 870 board), my board can auto volt upto 4.3Ghz but will prolly aim for a touch more than that, seen as default prime 95 has only hit 27C according to core temp (lowest, I kid you not, is 2C)
wires are gunna be ok as they are, as mobo 2nd connection wasn't playing nice (may get an extension for it), added the short fan leads to it too as part of the cooler, bottom hey its mine, so as long as they stay on the bottom its fine by me as won't be doing much to the air flow anyway as a nasty sata hd in there at mo.
