Built for the EXTREME!
20 Jul 2009
The bleak North East arm pit of Britain
Tired of your PC falling over because of failed overclocks and high temps? You need TUF!
Check out the awesome TUF boards we have below and in stock. All of which are tested to the extreme to ensure stability and longevity no matter the weather :cool:
Asus X79 Sabertooth Intel X79 (Socket 2011) DDR3 Motherboard @ £266.99 inc VAT
Intel X79 Chipset, x8 DDR3, x3 PCI-E x16, x1 PCI-E x8, x2 PCI-E x1, x4 SATA 6GB/s, x4 SATA 3GB/s, x2 eSATA 6GB/s, x6 USB 3.0, x14 USB 2.0, x1 Gigabit LAN, HD 8 Channel Audio, Xfire & Tri-SLI Support
Only £266.99 inc VAT.
ORDER NOW
Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX Motherboard @ £199.99 inc VAT
Intel Z87 Chipset, x4 DDR3, x3 PCI-E x16, x3 PCI-E x1, x8 SATA 6GB/s, x1 Gigabit LAN, x6 USB 3.0, x10 USB 2.0, 7.1 HD Audio, SLI & Xfire Support
Only £199.99 inc VAT.
ORDER NOW
Asus Z87 GRYPHON Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard @ £133.99 inc VAT
Intel Z87 Chipset, x4 DDR3, x2 PCI-E x16, x1 PCI-E x1, x8 6SATA 6GB/s, x1 Gigabit LAN, x6 USB 3.0, x8 USB 2.0, Realtek ALC1150 Audio, SLI & Xfire Support
Only £133.99 inc VAT.
ORDER NOW
Asus Z77 Sabertooth Intel Z77 (Socket 1155) DDR3 Motherboard @ £188.99 inc VAT
Intel Z77 Chipset, x4 DDR3, x3 PCI-E x16, x3 PCI-E x1, x6 SATA 6GB/s, x4 SATA 3GB/s, x1 Gigabit LAN, x6 USB 3.0, x10 USB 2.0, 7.1 HD Audio, SLI & Xfire Support
Only £188.99 inc VAT.
ORDER NOW
Asus Sabertooth 990FX R2.0 AMD 990FX (Socket AM3+) DDR3 Motherboard @ £158.99 inc VAT
AMD 990FX Chipset, x4 DDR3, x4 PCI-E x16, x1 PCI-E x1, x1 PCI, x6 SATA 6GB/s, x2 SATA 3GB/s, x2 eSATA, x1 Gigabit LAN, x4 USB 3.0, x14 USB 2.0, Realtek 7.1 Audio, SLI & Xfire Support
Only £158.99 inc VAT.
ORDER NOW
