Built in web cam
14 Dec 2004
South
I have a built in webcam on my new laptop, but nothing knows its there. Cant find anything in control panel about it.
Is there any standard thing to do to make them work?
Cheers
i'd go and check control panel and then system then hardware then device manager and check that the web cam is there, it should be under USB Devices i think, well i assume it would be :o
the webcam should just work, have you tried it on say msn or perhaps microsoft movie maker? it should come up a source on there to record from.
I went through all control panel and never found anything. MSN wouldnt work, said there was no camera.
Dug out the manual on CD and loaded that up. Found a hot key. Activated that, and it loaded all the drivers. Thought it would have all been installed if I bought a pre installed laptop. Llaptop doesnt seem to have any of the software the manual talks about for videoing, but its working now and showing on MSN.
Cheers guys.
