Built my new system it is Awesome with pics
Hi all, I went with the advice on this forum and I ordered the parts below from OCUK. All was fine with the delivery and service was great and it turned up friday minus the sound card which 5UB explained what happened so im happy to wait on that.
pc spec 26 10 2012 by acharris_77, on Flickr
My email to say the order was sent turned up late at night which concerned me and also my account never updated but all sorted after. I am well impressed with the system though based on the parts. It is lightning quick and games just look awesome on it.
The cooler was a bit of a Pain though, especially the stupid back screw. I tried 7 different screwdrivers to fit down the hole but none fitted
, finally had to use the little spanner thing to slowly tighten it, but got it fitted and it works fine and cool. I will get pics up when I get 5 mins as the cooler only just fitted in my P182.
Also watch the board and GPU combo as the card do sit slightly on the white SATA ports at the end of the board, but it dont cause any fitting issues or vibration.
, finally had to use the little spanner thing to slowly tighten it, but got it fitted and it works fine and cool. I will get pics up when I get 5 mins as the cooler only just fitted in my P182.Also watch the board and GPU combo as the card do sit slightly on the white SATA ports at the end of the board, but it dont cause any fitting issues or vibration.
