- 10 May 2007
Hi all,
I recently tried to replace the bulbs in the lanterns at the front and rear of our property.
It had a E16 bulb fitted, which upon searching on google, I found little in the way of bulb options.
Upon investigation, the actual lantern itself states that it should have E27 bulbs fitted, which are readily available.
Before I complain to the builder (new build), can anyone confirm if E16 bulbs are compatible with E27 bulbs? From a fitment point of view, it appears so. However the bulbs did fail within a year.
Regards
Regards
