I'm currently on the 8mb Bulldog package and up until recently I've (pretty much) always got a solid 6.5-7.0mb connection!
The trouble is the connection speed now seems to be all over the place - one minute its fine and firing at 6.5mb (maxing out at just under 800kb/sec) and the next its dropped to less than a meg!! (struggling to get 100 kb/sec)
I'm still using the same equipment, a Linksys WAG54GS router and wireless USB connection.
The only thing I can point to is I've just had a new kitchen, which is where the master socket is - could this be the problem if its been disturbed?? (although it all seems pretty well secure!?!)
The main wire comes in through the window frame and into a small oval BT box that I'm told is the master socket (albeit an old one!) and then is hardwired into a socket in the kitchen and also seperately hardwired back outside, up the wall and into one of the bedrooms. (microfilters in both!)
Does anyone know if I'll be able to get Bulldog to replace the age-old oval "box" and install a brand spanking new one???
Any advice is appreciated
Many thanks....
StevieP
Many thanks....
StevieP
