- 8 Aug 2010
- Oxfordshire
"The donanimhaber.com crew has run an engineering sample of AMD’s new FX-8130P through its paces and the results are very positive.
Although the chip fails to keep up with Intel cores in the SuperPI test, as we have already seen, it pulls ahead in other tests. For example, in x264 encoding tests, Bulldozer scores 136fps in the first pass and 45fps in the second pass, whereas the Core i7 2600K manages 100fps and 36fps respectively."
http://www.fudzilla.com/processors/item/23381-bulldozer-performance-figures-are-in
, as when i meant 'stock speeds', i was thinkng 3.2Ghz...that has been said to be the stock speed.
