**BUNDLE DEAL: BENQ XL2420T + 3D VISION 2.0 KIT + BATMAN & A DISCOUNT!!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK, due to popular request, we've thrown a bundle together which consist of the amazing XL2420T Monitor, 3D Vision 2.0 Kit & Batman Arkham City PC Game, even more impressive you also get a discount too over buying the parts seperately for more savings:-
Benq XL2420T 24" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor & 3D Vision 2.0 Kit - Bundle with FREE Batman Arkham City PC Game @ £392.99 inc VAT
The XL2420T demonstrates BenQ’s true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming monitor like no other – from the attentive designs to the exceptional functions. With the precision and speed you would expect from a high-performance gaming monitor, you can now have a vantage point over your opponents in all your game play.
The task of conceptualizing the XL2420T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy “Potti” Ingemarsson, Emil “HeatoN” Christensen, Abdisamad “SpawN” Mohamed, Michael “ahl” Korduner and Christer “fisker” Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning.
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2420T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you’re able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:9), 21.5"W (16:9), 22"W (16:10), 23"W (16:9) to 24"W (16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
The preset FPS mode tailored by HeatoN and SpawN gives you the optimal brightness, contrast, sharpness and color tint in FPS games so you can spot your opponents and track their every move, even in indistinct situations. There are two variations to this special mode this year: the FPS1 mode is designed for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
With a refresh rate of 120Hz, there’s never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2420T gives you on-screen action and captivating realism.
Fast response time of 2ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of slow display.
The newly designed OSD enables you to conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by HeatoN and SpawN so you can see what the pros see. Each mode is fine tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. Users can install these exclusive presets and leverage them to their advantage. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2420T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action.
Features:-
- Product Color: Black-Red
- Screen Size: 24"W LED-backlight
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.276 mm
- Brightness: 350 cd/m²
- Contrast Ratio: 1,000:1 / DCR:12,000,000:1
- Response Time: 2 ms GtG
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Display Color: 16.7 million
- Color Gamut: 72%
- Terminals: D-sub / DVI-DL (Dual Link) / HDMI x 2 / DP 1.2 / Headphone Jack
- USB Hub: Donwstream x3; Upstream x1
- Color Temperature: Reddish / Normal / Bluish / User mode
- Features: Black eQualizer, Smart Scaling, FPS Mode, RTS Mode, Game Mode Loader, NVIDIA® 3D Vision™ 2 ready, Senseye 3, AMA
- HDCP
- K-Locker mount
- Height adjustment: 130mm
- Tilt (down / up): -5 / 20
- Swivel (left / right): -45 / 45
- Pivot: 90°
- 571.4 x 516.9 x 149.9 mm
- Gross weight: 6.1 kg
- VESA Wall Mounting (mm): 100 x 100 mm <
- 2yr On-Site Warranty
- Supplied with Batman Arkham City PC Game
Discover the difference NVIDIA® 3D Vision™ 2 can make in your PC gaming experience. The new gamer-inspired 3D glasses have 20% larger lenses to give you the most viewing area with the least light leakage. They also work great with the innovative NVIDIA 3D LightBoost™ technology, which makes your screen up to 2x brighter for better 3D gaming and video viewing. Plus, 3D Vision 2 glasses are built from state of the art, softer materials designed to deliver more comfort and better fit.
BETTER PC GAMING
Play over 600 PC games in 3D including the latest titles like Batman: Arkham City, Crysis 2, and L.A. Noire. Enjoy softer composite materials and better fit with gaming headsets. Get best-in-class 2D gaming with ultra-smooth 120 fps gaming on 120Hz monitors
BRIGHTER 3D
Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology. Experience the new external light blocker that minimises the effects of overhead lighting
MORE IMMERSIVE
Try the new 27'' 3D monitors from ASUS and Acer for Full HD 1080p 3D and ghost-free image quality. Experience games more fully with 20% larger 3D lenses for an ultra wide viewing area. Get the most diverse ecosystem of content-including 3D photo sharing and browsing-on 3DVisionLive.com
Was [£404.99] Inc. VAT
Only £392.99 inc VAT.
ORDER NOW
