Bundles now at OcUK!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Carbide Enthusiast Bundle @ £182.96 inc VAT
OCUK have teamed up with Corsair to provide a selection the of best enthusiast grade hardware for your overclocked gaming system, including a builder-friendly performance case, super-efficient power supply and premium hydro CPU cooler, you can be assured your selecting the best components for your new system.
Included in this bundle:
- Carbide 300R Mid Tower Gaming case
- 650Watt Enthusiast TX650V2 80Plus Bronze Rated Power Supply
- H60 Hydro CPU Cooler for Intel and AMD Sockets
The Carbide Series™ 300R is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5" SSD compatibility. There's room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There's room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
The Enthusiast Series TX V2 is part of Corsair's best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a new micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable new technologies to an affordable price point. If that weren't enough, the H60 also features an all-new fan, custom designed to offer enhanced static pressure, which means better cooling.
You don't have to sacrifice performance to build a quiet system. Most high-performance coolers use crude, outdated designs that rely on two techniques: put a huge hunk of metal in your case or crank the fan to obnoxiously loud noise levels. The Hydro Series coolers feature innovative, cutting-edge designs that utilize the superior thermal conductivity of liquid over air to provide fantastic cooling at much lower noise levels. In fact, the H60 is similar in noise levels to a 120mm case fan you probably already have.
Almost any case with a rear 120mm fan mount location can house the Hydro Series H60 CPU cooler. And don't worry about compatibility with your CPU, we've got you covered. AMD® sockets AM2 and AM3 are covered, and without having to install a custom backplate, making the H60 a great choice for any modern AMD CPU up to the new Phenom six-core processors. And when it comes to Intel®, don't worry about it. Whether you've got Socket LGA775, LGA1155, LGA1156, or LGA1366, we've got compatibility inside the box. That's right, even the brand new Core i5 and Core i7 2x00 series processors are supported, right out of the box.
Only £182.96 inc VAT.
ORDER NOW
Corsair Graphite Enthusiast Bundle @ £304.98 inc VAT
- Graphite Limited Edition 600T White Mid Tower Windowed Gaming case
- 750Watt Enthusiast TX750V2 80Plus Bronze Rated Power Supply
- H80 Hydro CPU Cooler for Intel and AMD Sockets
The Graphite Series™ 600T makes it easy to build a world-class gaming system. With excellent cooling from the dual 200mm fans, eight PCI-E expansion slots to accommodate multiple graphics cards, and plenty of room for large, power-hungry components, the Graphite Series 600T can handle just about anything you can throw at it, the case is mid-tower in height, but inside it's positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren't enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade. The Special Edition White 600T also includes a new custom side panel with a cutout for a window (pre-installed) or included mesh insert with room for up to four 120mm fans for even more outrageous cooling!Corsair innovated cable routing with the Obsidian Series™ cases, and the Graphite Series features the same ingenious design. Pre-cut holes in the motherboard tray with rubber grommets and plenty of room behind the motherboard to route cables for a clean, uncluttered interior. The optical drive bays are tool-free, the side panels easily detach with the built-in latch mechanisms, and the integrated fan controller allows you to choose between quiet operation or maximum cooling performance.
The Enthusiast Series 750WTX V2 is part of Corsair's best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
The Corsair Hydro Series H80 liquid CPU cooler provides a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans. It also includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*.
* Requires the Corsair Link Commander, sold separately
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
Double-up for excellent cooling
Featuring a double-thick radiator to maximize the surface area available for heat dissipation, and dual, performance matched fans, the H80 delivers cooling performance that lets your CPU keep its cool, even when pushed to the limit. And with all this cooling performance, the compact design still fits virtually any case with a 120mm fan mount.
Only £304.98 inc VAT.
ORDER NOW
Corsair Obsidian Stealth Enthusiast Bundle @ £301.98 inc VAT
Corsair Obsidian Stealth Professional Bundle
- Obsidian 550D Quiet Mid Tower Enthusiast case
- 850Watt Professional HX850 80Plus Silver Rated Modular Power Supply
The Obsidian Series™ 550D has been carefully engineered for noise reduction. The front and side panels are insulated with sound dampening material, and the hard drive trays and fans have soft silicon mounts to absorb vibration. The top and side panel vents are covered for noise reduction if you're not using them to install your own fans, and even the intakes are angled to reduce air noise.
The rigid, stamped steel and brushed aluminum case holds some remarkable technology that makes it easy to build great systems. There's built-in USB 3.0 support, and the drive trays work with 2.5" SSDs. The removable hard drive bays allow customization for extra-long graphics cards and maximizing airflow. And, the easy-access side panels come off at the touch of a button for easy upgrades or simply admiring your work.
The Corsair HX Professional Series 850W power supply sets a new standard by which all premium PSUs must be judged. Designed and engineered using cutting-edge technology, each Corsair Professional Series power supply is built to the highest quality standards, and delivers the features and performance that technology enthusiasts demand including modular cabling and 80Plus efficiency.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles.
Only £301.98 inc VAT.
ORDER NOW
Corsair Obsidian Extreme Professional Gold Bundle @ £509.98 inc VAT
- Obsidian 800D Full Tower Enthusiast case
- 1200Watt Professional Gold AX1200 80Plus Gold Rated Fully Modular Power Supply
- H100 Dual Radiator Hydro CPU Cooler for Intel and AMD Sockets
Designed for Years of Performance
The Obsidian Series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades.
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that's both serious and awe-inspiring, a windowed side panel makes it easy to show off your work.
Three Isolated Cooling Zones, the power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat build-up.
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The SATA hot-swap bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment. Need even more cooling performance? The Obsidian Series 800D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
A four-drive SATA 6GB/s hot-swap drive bay sits in the front of the case, making it easier to install or swap hard drives on the fly. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25" drives.
The Corsair AX Professional Series Gold 1200W power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you. All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling - the cables stay in place and connect to your new fully-modular Corsair power supply. With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus® Gold seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery.
The Corsair Hydro Series H100 CPU Cooler Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*. (*Requires the Corsair Link Commander, sold separately). The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool blue LED display lets you know at a glance which profile is being used.
Only £509.98 inc VAT.
ORDER NOW
Only corsair???
Nope!
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black / Antec High Current Gamer M 520W "80+ Bronze" Modular Power Supply @ £146.98 inc VAT
Antec’s popular and award-winning Nine Hundred gaming case became an instant favorite among gamers, delivering versatility, style and performance to establish itself as “The Ultimate Gaming Case.” Now Antec introduces the Nine Hundred Two, the next generation in premier gaming enclosures. Building on the tried-and-true designs of both the Nine Hundred and the powerful Twelve Hundred gaming cases, the Nine Hundred Two maintains popular features such as a perforated front panel, up to six variable-speed fans for maximum cooling, and a sleek, aggressive aesthetic. The Nine Hundred Two adds exciting improvements such as a top 200mm Big Boy TriCool™ fan now with blue LED, fan control knobs plus built-in washable air filters right in the front panel, and eight expansion slots for even greater versatility. Dominate your competition and maximize cool with the Antec Nine Hundred Two: “The Ultimate Gaming Case, Evolved.”
- 9 drive bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3 x 3.5" for HDD, or
- External 9 x 5.25"
- Advanced cooling system:
- 1 rear 120 x 25mm TriCool™ blue LED exhaust fan
- 1 top 200 x 30mm “Big Boy” TriCool™ blue LED exhaust fan
- 2 front 120 x 25mm special black blue LED intake fans with front speed control
- 1 side (Optional) 120 x 25mm fan mount
- 1 middle (Optional) 120mm fan mount
- Built-in washable air filters
- 8 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Front mounted I/O ports
- 2 x USB 2.0
- 1 x eSATA
- Audio In and Out (AC’97 and HDA compatible)
- Motherboard: Mini-ITX, microATX, Standard ATX
- No power supply included
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm double ball bearing fan complete the package. The HCG-520M features High Current Cable Management and 10-pin modular connectors. If loads of power, High Current engineering and extreme efficiency are what you're after, the HCG M is the PSU for you.
Features:
- 520 watts of Continuous Power
- 80 PLUS® Bronze certified — up to 87% efficient
-High Current Hybrid Cable Management — special 10-pin and 5-pin modular connectors for High Current rail
- Quiet 135 mm Double Ball Bearing cooling fan
- Stealth Wires: all wires darkened for minimal visibility in chassis
- All Japanese brand capacitors for reliability
- Thermal Manager: an advanced low voltage fan control for optimal heat & noise management
- Up to 90% power available on +12V rail
- ATX12V version 2.32 and EPS12V version 2.92 compliant
- Heavy-duty protection circuitry on all rails prevents damage from a variety of dangers:
- Over Current Protection (OCP)
- Over Voltage Protection (OVP)
- Under Voltage Protection (UVP)
- Short Circuit Protection (SCP)
- Over Power Protection (OPP)
- Surge & Inrush Protection (SIP)
- AQ5 — Antec Quality 5 year limited warranty on parts and labour
- MTBF: 100,000 hrs
- POWER SUPPLY CONNECTORS ASSORTMENT:
- 1 x 24(20+4)-pin
- 1 x 8(4+4)-pin ATX12V/EPS12V
- 2 x 8(6+2)-pin PCI-E
- 5 x SATA
- 4 x Molex
- 1 x Floppy
- Safety Approvals: UL, cUL, CE, TÜV, CB, FCC, CCC, C-Tick, BSMI
- Net Weight: 1.8 kg / 4.0 lbs
- Size:
- 86 mm (H) x 150 mm (W) x 160 mm (D)
- 3.4" (H) x 5.9" (W) x 6.3" (D)
Only £146.98 inc VAT.
ORDER NOW
Antec 1100 Eleven Hundred Ultimate Gaming Tower Case - Black / Antec High Current Pro 850W Modular '80 Plus Gold' Power Supply Bundle @ £204.97 inc VAT
The Antec Eleven hundred is the new beast in the Hundred Series range, with a price that beats the competition to the ground with features and technology that does truely astound.
- 0.8mm SECC Constuction
- Perforated, quick release front bezel
- Enlarged CPU cutout
- Windowed side panel and optional fan mounts
- Supports up to XL-ATX Motherboards
- 11 drive Bays
- Rubber grommetted cable routing holes
- Fits all Antec Kuhler H20 CPU Coolers
- Supports GPU's up to 330mm
- 9 Expansion Slots
- Front I/O Ports: Audio in/output / 2 x USB3.0 / 2 x USB2.0
- Tool-less 3.5" Drive bays x 6
- Easy install 2.5" Drive bays x 2
- Tool-less 5.25" Drive Bays x 3
- Top Cooling: 1 x 200mm Blue LED Fan
- Side Cooling: 1 x 120mm Fan (optional) - behind the motherboard to cool back of CPU
- Rear Cooling: 1 x 120mm Fan
- Front Cooling: 2 x 120mm Fans (optional)
- Internal Cooling: 2 x 120mm Fans (optional)
- Side Cooling: 2 x 120mm Fans (optional)
- 3 x Fan Filters
- 3 Year Warranty
Antec's HCP-850 unifies raw power with advanced PSU engineering to meet the demands of high performing PCs. A full-featured, 80 PLUS® Gold-certified unit, the HCP-850 is capable of outputting 99 percent of its rated power on four +12V rails, ensuring CPU and graphics card compatibility. Exclusive to the High Current series, HCP-850 boasts High Current heavy-gauge 16 AWG wiring that boosts conductivity, increasing efficiency and improving power delivery. In addition, a double-layer PCB, onboard DC-to-DC converters and Active Power Factor Correction (PFC) provide substantial voltage stability. To tackle the needs of your system, pick up Antec's HCP-850.
- 850 watts of Continuous Power
- 80 PLUS™ Gold certified - up to 92% efficient
- NVIDIA® SLI®-Ready certified, ATI CrossFireX™ certified
- High Current Hybrid Cable Management utilizes a 10-pin modular connector system
- Special heavy-gauge 16 AWG High Current cable for CPU connectors boosts conductivity, increasing efficiency and improving power delivery
- 2 x 8-pin CPU connectors included for dual-CPU gaming, server applications and high-end motherboards
- Gold-plated high-current terminals for optimal conductivity
- 135 mm double ball bearing PWM fan for optimal and quiet cooling
- Four fully-protected High Current +12V rails ensure high-end CPU and graphics cards compatibility
- Up to 99% power available on +12V rails
- DC-to-DC voltage regulator modules ensure stability and higher efficiency
- Highest quality Japanese brand capacitors for long-term reliability
- Double-layer PCB allows for heavy-duty components
- ATX12V version 2.3 and EPS12V version 2.92 compliant
- Full suite of industrial grade protection: - Over current protection (OCP) - Over voltage protection (OVP) - Short circuit protection (SCP) - Over power protection (OPP) - Over temperature protection (OTP)
Only £204.97 inc VAT.
ORDER NOW
Antec 1200 Twelve Hundred (V3 with USB3.0) Ultimate Gaming Case - Black / Antec High Current Pro 750W HCP750 '80 Plus Gold' Continuous Power Supply @ £234.98 inc VAT
Antec's Twelve Hundred V3 gaming case combines maximum performance, cooling and compatibility in a full-tower package. Thirteen drive bays, space for graphics cards as large as 17.5", a CPU cutout, an internal 2.5" SSD drive mount and newly integrated USB 3.0 round off a robust foundation for your components. The Twelve Hundred V3 features a top Big Boy 200™ blue LED cooling fan, two rear blue LED 120 mm fans and three front blue LED 120 mm fans. Apart from standard size power supplies, the Twelve Hundred V3 can accommodate Antec's CPX form factor PSUs. Outfit your components and maximize their performance with Antec's Twelve Hundred V3.
- 13 drive bays
- External 3 x 5.25"; Internal 9 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 9 x 5.25"; Internal 3 x 3.5" for HDD or
- External 12 x 5.25 for HDD
- Internal 1 x bottom-mounted 2.5" SSD drive
- CPU cutout allows for easy installation of CPU coolers
- Convenient top accessory tray
- 2 rear 120 mm blue LED exhaust fan
- 1 top 200 mm Big Boy 200&tradel blue LED exhaust fan
- 3 front 120 mm blue LED intake fans with front speed control
- 1 window side panel 120 mm fan slot
- 1 middle 120 mm fan bracket
- 200 mm Radiator mount
- Perforated front bezel for enhanced air intake
- 7 expansion slots to support multiple graphics cards, including NVIDIA 3-way SLI®
- Maximum video card size: 17.5" / 444 mm (Note: some video cards may require removal of the adjacent hard drive cage)
- 2 x USB 2.0
- 1 x USB 3.0
- Audio In and Out (AC'97 and HDA compatible)
- Motherboard mount: Mini-ITX, microATX, Standard ATX
- Power supply mount: Standard size PSUs or Antec�s exclusive CPX form factor PSUs
Raw Power Meets Unrivaled Performance
Antec’s HCP-750 unifies raw power with advanced PSU engineering to meet the demands of high performing PCs. A full-featured, 80 PLUS® Gold certified unit, HCP-750 is capable of outputting 99 percent of its rated power on its four +12V rails to ensure CPU and graphics card compatibility. Exclusive to the High Current series, HCP-750 boasts High Current heavy-gauge 16 AWG wiring that boosts conductivity, increasing efficiency and improving power delivery. In addition, a double-layer PCB and onboard DC-to-DC converters provide substantial voltage stability. To tackle the needs of your system, pick up Antec’s HCP-750.
SPECIFICATIONS:
- 750 watts of Continuous Power
- 80 PLUS™ Gold certified – up to 92% efficient
- Intelligent Hybrid Cable Management utilizes a 10-pin modular connector system
- All cables braided and wrapped for better airflow and neatness
- Universal Input – works on any 100V - 240V grid
- Active PFC with PF: 0.99
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- AQ5 Antec Quality 5-year limited warranty on parts and labor
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Dimensions: 3.4” (H) x 5.9” (W) x 7.1” (D)
86 mm (H) x 150 mm (W) x 180 mm (D)
- Net Weight: 5.5 lbs / 2.5 kg
Only £234.98 inc VAT.
ORDER NOW
Antec LanBoy Air Modular Gamers Case - Blue/Black / Antec SpotCool 80 System Cooler @ £143.99 inc VAT
Builders, inventors, dreamers and players of all types, meet the LanBoy Air, the most modular, most customizable open-air chassis. Nearly every part on this case, down to the motherboard and PSU mounts, is removable and customizable. A unique airflow design faces up to 15 total fans inward, creating positive internal air pressure that blows harmful dust and heat out and away from your prized components. Inside, the LanBoy Air’s exclusive AirMount™ HDD mounting system – the first of its kind – literally suspends drives in the air, providing superior vibration resistance and noise reduction. With 7 removable mesh panels, 9 drive bays, 8 expansion slots (including support for 3-way SLI), a USB 3.0 compatible front port and two internal 2.5” SSD mounts, the LanBoy Air is capable of thousands of possible configurations.
But really, the LanBoy Air is ideal for building just one type of computer: Yours.
- Fully-modular chassis
- Open-frame mesh panel construction
- AirMounts™ HDD suspension mount system for up to 6 HDDs
- 6 x internal 3.5” HDDs
- 3 x external 5.25” HDDs
- 2 x internal bottom-mounted 2.5” SSD bay
- Advanced cooling system - up to 15 fans
- Standard Cooling: 2 x front variable-speed 120 mm blue LED fans with stepless control knobs, 1 x rear 120 mm TwoCool™ blue LED fan, 2 x side 120 mm TwoCool™ blue LED fans for graphics cards cooling
- Optional fans: 2 x 120 mm fan for CPU and memory cooling, 6 x 120 mm side drive bay fan and 2 x 120 mm top fan
- Water cooling support: Top water cooling radiator fitting and Rear water cooling grommets
- 8 expansion slots for triple graphics-card configurations
- Maximum graphics card size: 16” / 406 mm
- Front I/O ports: 1 x USB 3.0, 2 x USB 2.0 and Audio (AC’97 and HDA compatible) In and Out
- Motherboards: Mini-ITX, microATX, Standard ATX
- Power supply not included
- Dimensions: 546 mm (H) x 269 mm (W) x 536 mm (D)
Antec's Spot Cool is specifically designed to mount on any motherboard to provide cooling wherever you need it most. Simply mount it on a motherboard mounting hole, angle the fan as you desire and power it from a motherboard fan connector. The 3-speed switch lets you balance quiet performance with maximum cooling. Get active cooling for your RAM, or expansion cards, or wherever your system needs it, and you'll see even better performance.
- Mount virtually anywhere inside a case
- Cools RAM & expansion cards
- Blue LED illumination
- Air Flow: 22.2CFM / 18.2CFM / 15.3CFM
- Speed: 3000RPM / 2500RPM / 2000RPM
- Acoustical Noise: 32.7dBA / 26.6dBA / 23.2dBA
Only £143.99 inc VAT.
ORDER NOW
Carbide bundle seems a very good deal indeed sir. Like the look of that case, think I've grown up going off windowed cases hehe.
Got a Graphite 600T 'White Edition' myself, fantastic case and a great deal all in for that :)
Just incase anyone is put off by the window it also comes with a Mesh insert to replace the window where you can mount up to 4x120mm Fans.
Got 4xWhite LED's on the side of mines right now to cope with the crazy temps this summer so far :p
Liking the look of the Antec 902 bundle, modular power supply too!
I know this is a bit off topic but they don't have CPU coolers bundles with them, so im looking at the Gelid Tranquillo to go with it, but is it the Rev. 2 version you stock? i know there isn't much difference but i'm just really picky over some things :D
