- 9 May 2010
- sheffield
Our house already had an alarm fitted when we bought it. Never had any documentation for it, just the code.
I have replaced one of the PIR units, and everything was fine. another sensor frequently errors ( blinking red light) so i have been opening it up and resetting it by taking the wire marked + out waiting a few seconds and re-applying it, it seemed to work for a few months before needing doing again.
I was doing it the other day and i think i may have shorted something, and now the entire system is dead, keypad no longer lights up door chimes stopped, everything is dead apart from the lights on the bell box, which i assume is on a different circuit. I have tried pressing all buttons on the keypad, switching off the fuse on the fuse board ( its wired in to the light circuit).
I'm weary of tampering any further as i don't have any ladders to disconnect the battery in the bell box if the alarm decides to start screaming.
Is there anything else i can try before i get some one in?
The key pad is a Pyronix sterling (can't find the documentation on the web)
Would it be worth getting a new system fitted? what would the likely cost be?
Thanks
GM
Thanks
GM
