Burning Blu-ray Discs
27 Dec 2005
Bristol
Ok, so I'm having an insane amount of trouble burning a Blu-ray disc.
What I have:
An LG BD burner
Sony Vegas Pro 8
Adobe Encore CS4
Nero
I'm able to build both a Blu-ray folder and ISO project in Encore.
If I try to burn a Blu-ray ISO in Nero it states that the ISO format is limited to 2GB. Clearly incorrect.
If I try to burn a Blu-ray UDF (only other option) and use the Blu-ray folder build, well, it basically just burns the folders as data.
So my question is, what do I build the BD project as, and what do I burn it as?
I'm at the absolute end of my tether with this. Please - someone shed some light and I will adore you forever.
I have no idea about encores burning stability.
Imgburn is your friend, It's free go grab it.
Nero was great years back, now it's silly bloatware. It is well documented that it has problems dealing with blue ray material.
Dont know.. :)..
Iso's are good as fragmentation of files should be sorted..
I guess testing is the only way.. Try to burn the disc at 1/2 the drives max speed first go.. to avoid any issues.
