AcidHell2 said:never mind, sorted it.
when you select the iso it automatically chnages it back to cd, you then hav eto tell it to burn to dvd. It's so stupid grrr..
But its done![]()
*Cough* ImgBurn *Cough*AcidHell2 said:never mind, sorted it.
But its done![]()
doesnt that just burn iso and a few other image files?MarcLister said:*Cough* ImgBurn *Cough*![]()
Its main feature is to burn stuff but it can build images for you. So you'd just tell it what to select from a folder and it can make an ISO image out of that and then burn it.AcidHell2 said:doesnt that just burn iso and a few other image files?
Is there any decent open source burning software, which does everything?
I would love to get rid of nero. I'm now pretty much entirely open source a few freeware and windows.
But never seen a good opensource burner.
Sounds interesting. So someone who has a Linux box on a Windows network or is able to transfer files between a Windows PC and a Linux box could use that then?BillytheImpaler said:The best CD/DVD burning software I've used is Gnomebaker. It's Free and open source and licensed under the GPL. However, it only runs on Linux and other Unix-like environments.
I don't see why not. To access the Windows share you'd install Samba, create a mount point using something likeMarcLister said:Sounds interesting. So someone who has a Linux box on a Windows network or is able to transfer files between a Windows PC and a Linux box could use that then?
Sounds cool. Will look this up in Fedora/Ubuntu when I get set-up. And username/password are my Windows details?BillytheImpaler said:I don't see why not. To access the Windows share you'd install Samba, create a mount point using something like
sudo mkdir -p /mnt/ntserver
then mount the network drive with
sudo mount -t smbfs -o username=usernamegoeshere,password=passwordgoeshere //ntserver/download /mnt/ntserver
Your distro will probably have a GUI tool for this as well.![]()
Yes sir, if you've enabled password protection on the share on your Windows machine.MarcLister said:And username/password are my Windows details?
Ah righto. Cheers.BillytheImpaler said:Yes sir, if you've enabled password protection on the share on your Windows machine.
LOL. What programs has it ripped off then?BoomAM said:That imgburn program looks like a rip off.
Just looked at the screenshots for it, looks like its ripped off several apps almost identically in GUI design. Wouldnt be suprised if it was more than the GUI as well!..
