burning problem
2 Jul 2005
hi i'm trying to burn iso file but i keep getting errors. i'm using ashampoo burning studio and infiniti blank cdr. my dvdr is pioneer 107d. it burns the file alright except after verification its comes up with this message
i don't know what's causing this error because i've burned many files before and nothing like this ever happened.
What exactly are you trying to burn? If you're trying to burn something illegal then maybe the software you're using will pick it up and stop you? Use Alcohol 120% for burning images anyway, lovely software :)
another good one i've found is cdburn.exe and dvdburn.exe which are free command line tools available in the Resource Kit. Very handy.
They even work on vista :)
thanks for the alcohol suggestion. i burned the file sucesfully without any errors. i have anoother img file which i can't burn win alcohol or nero without errors. i'm going to give imgburn a go
